Old 11-09-2009, 09:51 AM
00GTP4ME's Avatar
00GTP4ME 00GTP4ME is offline
Leaking Head?
A while back I noticed a bad oil leak that was spilling down on the passenger-side axle boot. I took it in and the shop said it was the valve cover gasket, so I had the valve cover gaskets replaced. The problem is that the oil leak doesn't appear to have stopped.
On Saturday I was changing the PCV valve and topping off the S/C'er oil so I tried to poke around back there to see if I could find where the leak might be coming from. I found some gunk around the base of the rear head and it looked like I had a leak coming from there. It didn't look too horrible so I'm not sure if this is the main culprit, but just the same, what would I expect to pay for a head gasket job (parts + labor)? I saw another thread that was about the same question, but didn't want to thread jack. Thanks!
2000 Pontiac Grand Prix GTP 3.8L SII V6 S/C
2000 Jeep Grand Cherokee Limited 4.7L V8
1996 Chevrolet Camaro Z28 5.7L V8
1993 Chevrolet Suburban K1500 5.7L V8
1991 Ford Probe LX 3.0 V6
1986 Ford Tempo GL 2.3L 4 cyl.
Old 11-09-2009, 09:57 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Leaking Head?
Lower intake gaskets and oil filter adapter to timing cover gaskets would be the two things I would focus on.
Old 11-23-2009, 12:10 PM
00GTP4ME's Avatar
Re: Leaking Head?
Took the GP to the shop today and I asked them to inspect the items you listed there. We'll see what they say....
Old 11-23-2009, 12:40 PM
danielsatur danielsatur is offline
Re: Leaking Head?
1) Is your auxiliary coolant tank contaminated with oil?
2) Do you see any Blow-by bubbles in your coolant tank?
3) How does your engine oil look?
4) Doe's your exhaust look like a steam engine?
Old 11-23-2009, 02:19 PM
00GTP4ME's Avatar
Re: Leaking Head?
  • No
  • Please explain.
  • Engine oil looks completely fine. No foam, no chocolate milk.
  • Exhaust is colorless and odorless. Tail pipes have no soot deposits.
Nothing leads me to believe the head is leaking other than what appears to be slight seepage around the base of the head.
Old 11-23-2009, 03:10 PM
Re: Leaking Head?
When a head gasket go's bad, exhaust blow-by, can cause bubbles in radiator and
auxiliary coolant tank.
Instead of a sweet (green) smell, it will smell like exhaust gases.
I would use a spray brake cleaner to clean your head off, and monitor your oil consumption.
Old 11-23-2009, 04:07 PM
Re: Leaking Head?
I wonder if this stuff works?
http://www.automotiveforums.com/vbul...d.php?t=948130
Old 11-23-2009, 08:24 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Leaking Head?
Could your oil leak be an LIM valley gasket?
Head gasket job on these car's isn't bad. If you have replaced the LIM Gaskets, you can do head gaskets.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 11-23-2009, 08:37 PM
00GTP4ME's Avatar
Re: Leaking Head?
Well I've had them replaced. I didn't the the replacing.
Old 11-24-2009, 09:15 AM
tblake's Avatar
In God We Trust
Re: Leaking Head?
If you can do body work, you can do LIM and Head Gaskets! I have no patience for body work. My jobs always end up looking worse than when I start!
Old 11-24-2009, 09:23 AM
00GTP4ME's Avatar
Re: Leaking Head?
If you replace a head gasket, don't you have to have the head resurfaced?
Old 11-25-2009, 10:47 AM
00GTP4ME's Avatar
Re: Leaking Head?
Got the GP back from the shop. They said that the entire back half of the engine was completely saturated with oil which made it hard to tell where the leak was coming from. They said that the oil seemed the freshest around the oil sending unit and suggested that I replace it. So i went for it and will be spraying off the engine as back as I can to see if that takes care of it. The oil level was really dropping frequently so if that stops too, that's a good sign. Hopefully that's all it was.
Old 11-26-2009, 02:13 AM
tblake's Avatar
In God We Trust
Re: Leaking Head?
Ah, or else the oil filter adapter gasket. (common problem and relatively easy repair).
Old 11-26-2009, 02:28 AM
00GTP4ME's Avatar
Re: Leaking Head?
I'm all about the easy repairs!
Old 11-26-2009, 10:22 AM
tblake's Avatar
In God We Trust
Re: Leaking Head?
http://www.zzperformance.com/grand_p...=349&catid=103
