Old 11-08-2009, 11:43 AM
massengill_mike massengill_mike is offline
engine swap base to z24
I was wanting to change my 1999 base cavalier engine and swap it with a 99 z24 would that fit with out changing the motor mounts
Old 11-11-2009, 03:56 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: engine swap base to z24
Nope, have to change engine mounts, transaxle, PCM, and wiring harness.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 12-06-2009, 05:30 PM
clutes1973 clutes1973 is offline
i've heard many good things about the 99 z24 engine. however... i've had nothing but problems and wouldn't put that hell on anyone. i've done nothing to sup it up. all my stuff has been to keep it going. always timing related issues. piece of sh%t!!! mine is dead as we speak!
J-Ri you really seem to know your sh&t wish you were right here for mine. even my mechanic is presently stumped.
Old 12-07-2009, 08:46 PM
J-Ri's Avatar
They were very good engines for their time, but as is always the case with old technology, they're outdated. They make good HP for the displacement, but are still mostly reliable. A PITA to work on, but no worse than many other comparable engines from other manufacturers.
