Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 11-08-2009, 11:06 AM
spartfaithful spartfaithful is offline
97 Dodge Neon engine reving
I have a 97 Dodge Neon that we dont drive to often but lately when the car is in gear and you press the gas pedal it revs for a second or two then catches into gear. This happens just about everytime we are driving now, either while driving from a dead stop or slowing down to make a turn then trying to speed up again. Not sure if this is transmission related or not.
A second is is that the speedometer works intermittentl. Sometimes it will work all the time others the needed will jump from 0 to the MPH while driving.
Any help on either issues is appreciated.
Old 11-09-2009, 07:50 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: 97 Dodge Neon engine reving
Check the fluid level for your transmission, it may be low. If it is low, only use ATF+3 or ATF+4. No Dexon/Mercon fluids!!!
Give this a shot for your gauge problem...
http://forums.neons.org/viewtopic.php?t=118450
2003 Dodge SRT-4
