Go Back   Automotive Forums Car Chat > Jeep > Liberty
Old 11-08-2009, 03:38 AM
littleshelly littleshelly is offline
Sputtering and stalling when turning right
Hi, I have a 2006 Jeep Liberty Sport 4WD. It has been sputtering and lately when I make a right turn it almost stalls. Once it did. If I bump the gas and speed up it seems to go. But it is getting worse. This happens regardless of the fuel level. I am worried about taking it in to be repaired my mechanic has 2 jobs and is too busy to look at it so I am going to have to take it somewhere else and don't want to be taken advantage of. What could this be?
Also this may be related or unrelated. I bought the Jeep used and the power windows, especially the drivers side window is very slow when going up and down and sometimes does not work at all. This does not happen all of the time but seems to happen more when it is cold outside. I took it back to the dealership and they had no problem with it since it only happens some of the time. They took the window out and greased it he said but I still have the problem. I have to physically pull the window up while pushing the power button when it gets stuck. The batter in the Jeep is new. Thank you for any advice. This is my only car and it must be dependable.
Old 11-22-2009, 08:01 AM
rhandwor rhandwor is offline
Re: Sputtering and stalling when turning right
Auto Zone and Advanced will check the battery and charging system free. I would start here make sure the battery is clamped down and doesn't move.
Old 11-22-2009, 03:42 PM
Hi and thank you for the reply. The battery is brand new. Just replaced it 2 months ago.
Old 11-24-2009, 11:04 PM
hundahunta hundahunta is offline
possibly needs a tune-up and checked fuel pressure
Old 11-25-2009, 02:00 AM
Thank you, I have a guy at work who works on my cars. He is busy but is suppose to get it in soon. I do belive it has something to do with the fuel.
Old 11-25-2009, 05:58 AM
Use a can of carburetor cleaner and spray the sides of the intake. Any place it hits an air leak the engine will smooth out and run properly. What an air leak does is lean out the mixture and they don't idle correctly. Also look at the fuel pressure regulator. If it has a vacuum hose on it pull the hose and if it has gas in it replace.
This is newer than I have experience on and some of newer vehicles are redesigned but intakes leaks still effect them.
Old 11-26-2009, 05:20 PM
Thank you for the advice. I will print it out and try it.
