Old 11-07-2009, 11:28 PM
cHo's Avatar
cHo cHo is offline
Got a ? about SAFC vs 660cc injectors
So I got my td05 kit installed and already pretty much maxed out my 450cc injectors at 14.5psi on a basic safe tune. Been talking to a friend about going either 580cc or 660s. I hear and read most people don't recommend going over 550cc on the SAFC2 even though technically the max would be 720ccs according to the math. I was told that if you can use up the injector(keep your IDCS around 90%) then I won't have to worry about aggressive timing advance. Is this true or no? I also have a AFPR I have waiting to be installed so I can always turn up the base fuel pressure. I just don't want to keep buying injectors and maxing them out and having to spend more money on new ones. However, I don't want to worry about crazy timing advance and blowing my motor. Anyone got some helpful knowledge? Thanks.
-cho
Old 11-08-2009, 01:39 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Got a ? about SAFC vs 660cc injectors
If no one else pipes up by morning I'll do some searching and get you in the right direction.
Old 11-08-2009, 02:07 AM
vr4choke's Avatar
vr4choke vr4choke is offline
Send a message via AIM to vr4choke Send a message via MSN to vr4choke
do you have a stock fuel pump? i dont think the stock one can supply enough for 660s. not sure tho
Old 11-08-2009, 09:31 AM
cHo's Avatar
cHo cHo is offline
No I have a walbro 255 hotwired. Thinking about going with a bigger pump if I go with the 580s so I won't have to worry about losing pressure at higher boost levels.
Old 11-08-2009, 02:20 PM
toddrs93's Avatar
toddrs93 toddrs93 is offline
-cho
it can be done but it will definitely be your weak spot. Yes generally SAFC's are not well over 5500cc, plus with a TD05 kit and that much fuel you really need some kind of timing control. Typical target for the injectors is really 80%. If it is a 16g kit, with typical mods, I would say 500whp is your limit, but with full management so that you have timing control and more accurate fuel control you should be able to reach 600whp.
Old 11-08-2009, 05:34 PM
cHo's Avatar
cHo cHo is offline
if I could keep the idcs in control, wouldn't timing stay on the stock map even with the bigger injectors?
Old 11-09-2009, 10:49 AM
Girly VR-4 Girly VR-4 is offline
you run an afc with anything larger than 550's, and you'll end up blowing your engine. the s-afc can not handle the fuel flow of anything bigger.
get a greddy e-manage or something of the like.
www.groundzeroperformance.com
www.3swarehouse.com
1991 Stealth R/T Twin Turbo... sitting...
1996 Orchid Pearl Stealth R/T.... daily driver duty, 275k+ miles and counting!
1995 3000GT Spyder SL... being modified...
