Old 11-07-2009, 07:58 AM
ned032002's Avatar
ned032002 ned032002 is offline
Fuel Tank seal
Need the fuel tank seal for my 91 Eclipse GSX. Do any of you guys have a mitsu dealer around you that you can order parts from? No one around here can get it.
Old 11-07-2009, 01:05 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Fuel Tank seal
So you have tried to order the part from a store but they dont have it and you dont have a dealer around you? I would just put some silicon on that and put it back together. That red RTV silicon is fuel resistent so that should work fine.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-07-2009, 05:11 PM
ned032002's Avatar
Re: Fuel Tank seal
Tried all the local places with no luck. The closest mitsu dealer is about 2 hours away. I think I might just do that with the rtv, the guys at autozone said to use the black stuff. That's the stuff I was going to use anyway but should I not?
Old 11-07-2009, 05:24 PM
Holset powered 420a
Re: Fuel Tank seal
Either one should work fine.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-08-2009, 07:27 AM
ned032002's Avatar
Re: Fuel Tank seal
So the black stuff is fuel resistant too? I'm sure it will be fine but just wanted to check again.
Old 11-08-2009, 12:18 PM
Holset powered 420a
Re: Fuel Tank seal
Im not really sure about the black stuff. It will say on the package whether its fuel resistent or not. Just make sure whatever you get is
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-10-2009, 02:15 PM
ned032002's Avatar
Re: Fuel Tank seal
I got some silicon that resists gas, oil, karasene, and a bunch of other stuff. It comes in a white tube, it was the only one that resists gas.
Old 11-10-2009, 02:21 PM
Holset powered 420a
Re: Fuel Tank seal
Should work fine. Let us know how it turns out.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-10-2009, 02:23 PM
ned032002's Avatar
Re: Fuel Tank seal
Like to get it done today but gotta get motivated. My daughter has the swine flu so at home dealing with that all day.
Old 11-10-2009, 02:32 PM
Holset powered 420a
Re: Fuel Tank seal
Well that sucks, hope she feels better. Good luck with the pump. Take some pics for us.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-10-2009, 07:34 PM
ned032002's Avatar
Re: Fuel Tank seal
Well finally got out there and just got it done. I got the dremel on sunday night so I started cutting the nuts and studs off that night. I blew through like 6 cut off discs and decided to get something a little bit more durable. I bought some reinforced discs on monday and did some more cutting last night. I also drilled the new holes through the sending unit where the new self tapping bolts would go. I cleaned up what was left of the nuts and I was able to use my finger nails and pull the sending unit up and out. I thought I was going to need a small pry bar but I managed with the claws of life. Well any way since I had the other sending unit all ready to go I just put a ton of rtv on it and put it in place. There was enough of the studs left that all I did was drop it in place where the holes lined up. I was kind of afraid to use a drill around the gas fumes because of the sparks you sometimes get in the internals of the drill itself. I tried to put the self tappers in by hand but I got no where doing that so I just winged it and used the drill. I just used it to get the bolts started then I tightened them by hand. It may look like a hack job but I really didn't have many other options with the tight quarters I was working in. I'm just hoping that it seals properly that's my only concern. I just have to finish up the rewire with the 2 wires left to connect and reinstall the cover plate and I'm done with all this shinanigans. I hope to get the rewire completed tonight so a couple more pics maybe later. I guess I can add the rewired 255 to my mod list if theres any more room.
Got 2 pics:
before
after
Last edited by ned032002; 11-10-2009 at 07:39 PM. Reason: Also entered in Members section
Old 11-10-2009, 11:28 PM
Holset powered 420a
Re: Fuel Tank seal
Good idea with the self tapping screw. That should work perfect. It looks a hell of a lot better all cleaned up.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-11-2009, 07:52 AM
ned032002's Avatar
Re: Fuel Tank seal
Yeah I predrilled through the sending unit because that way when I put the self tappers in it would pull the tank up instead of pushing it away and risk bending up the sending unit. I had a week to plan the whole thing so it all worked out great. I'm just concerned about the seal is all. If I have to pull it back apart at least this time it won't be difficult.
Not to mention I had to do it all quick once the seal was broken on the old sending unit because I was doing this in the garage where a hot water tank and furnace is running. Once I had the seal broke I couldn't just stop for the night because of the fumes, so I'm glad the plan worked out.
