Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 11-06-2009, 09:15 PM
erndogy erndogy is offline
Back-up light help
OK once I got my daughters neon going after a cylinder head replacement, I did a walk-around and found the back-up lights do not come on. I checked the fuse with a lamp and it good. No power to the back lights. Checked with a DMM. Looked in the haynes book for help but they only show the manual tranny switch location. I see two of them towards the front of the car. A round one with three wire connector, I believe its called the neutral start switch. And there is another one about eight inches to the left of it and on the top. (looking from the top front of the engine) The book does not describe that one. Could that be the back-up light switch? Or the round one on the front side it? Or is in neither?
Thanks
Erndogy
Old 11-06-2009, 10:41 PM
hundahunta hundahunta is offline
Re: Back-up light help
yup I would jump that connector and check with lights
Old 11-09-2009, 06:56 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
When standing in front of the vehicle, the switch is located on the top right hand side of the tranny. It will be just underneath the clutch cable.
2003 Dodge SRT-4
Old 11-10-2009, 10:06 AM
Thanks for the replies but the switch is working. After reading a post about the back-up lights working only when the shifter was between reverse and neutral I had my daughter sit in the car and move the shifter slowly between the two and the back-up lights come on when the shifter is in the middle.
Is there and adjustment that can be made to correct that?
Erndogy
