Originally Posted by bigevil20
I want to replace my front brake drum on my 55 chevy truck. I need to remove 3 rivets that holds the hub to the drum in place and install that hub to the new drum. Can I take it to a brake shop that can re-install the rivet?
I seem to recall the wheel studs go through the hub and drum then is deformed or swaged similar to a rivet, right?
Imo take the old drum and hub, and the new drum to a competent machine shop and have them do the entire disassembly and reassembly process.
Imo if you try to disassemble it yourself, you may ruin the 'sample' that a machine shop would need to do a proper job.
So, imo, leave it alone and let a machine shop swap them for you.
Finally, I'm pretty sure a brake shop would not do such work themselves. They would send it out to a machine shop then charge you 25% in addition to the machine shop charge.
