2000 Grand Prix Head Gasket Replacement
I need to replace my head gasket on a 2000 Grand Prix GT, with a 3.8 engine. Where can I find detailed instructions on how to do this??
Re: 2000 Grand Prix Head Gasket Replacement
Here is about all I have, but it should help you along the way with removing your LIM.
http://www.automotiveforums.com/vbul...d.php?t=951637
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
Thanks!!
Couple of things...the job gets bigger from the LIM, especially removing the exhaust manifold studs and bolts and the crossover pipe which are bound to be in less-than-pristine condition after nearly 10 years of running around. The coil pack bracket also is attached to the LH bank/1-3-5/front cylinder head. The rocker arms are net-build without any adjustments needed other than to properly torque.
I would pay close attention to cleanliness inside there. Shop vac makes a lot of sense in my thinking. I knew a guy who could go start to finish on changing heads on a 3800 in 8 hours' time, using air tools for disassembly and torque wrenches for reassembly. The guy was well-practiced and was flying the entire time. Plan for the rest of us mortals to take 2-3 days. I would also purchase new head bolts, pay attention because there are two lengths, one inside the head and one outside. I believe the head bolts are torqued to plastic yield and should be replaced with new. I would pay attention to the original torque-plus-angle strategy. While you are at it I would install new rocker cover gaskets as well.
1988 Chevy R-30 1 ton DRW pickup (217k) 1991 Chevy S-10 4WD pickup (192k) 2000 Grand Prix GTP (218k) 2002 GMC Yukon (185k) 2009 G8 - GT (46k) |
Good Point, it may be a good idea to start soaking down your exhaust manifold studs right now. 8 hours seems like a pretty good time! But dont get in a rush. What is the flat rate book time on these?
