Old 11-06-2009, 05:25 AM
SamNovice SamNovice is offline
rough engine at very low speed
I have 98 Windstar with 175K miles. It idles fine, and runs fine except one problem. When I push the gas pedal lightly to go, the engine gets very rough (almost about to die). If I push the pedal slightly more, engine smoothes out immediately and runs fine. I tried one of fuel cleaners and it had no effect. Any thoughts?
Old 11-06-2009, 08:10 PM
Ed_Strong's Avatar
Ed_Strong Ed_Strong is offline
Son of a Mechanic
Re: rough engine at very low speed
First thing I can think of is to have the IAC (Idle Air Control) Valve cleaned!
Current Rides:
2018 Honda Pilot EX-L - 3.5L V6 -{|}- 2004 Toyota Matrix XR 4WD 1.8 I4
________________________________________
Past Rides:
2000 Ford Windstar LX - 3.8L V6 SFI - {|} - 2003 Ford Expedition XLT - 4.6L V8 SFI
2005 Chevrolet Malibu LS - 3.5L V6 SFI - {|} - 1991 Chevrolet Corsica LT - 3.1L V6 MFI
1995 Dodge Grand Caravan SE - 3.3L V6 MFI - {|} - 1980 Ford Mustang - 3.3L L6 1BBL
Old 11-06-2009, 08:15 PM
wiswind wiswind is offline
First thing would be to make sure that you are up on routine maintenance, fuel filter, air filter, spark plugs/wires.
A can of Berryman's B-12 Chemtool in the gas tank to clean the injectors.
A good inspection of the vaccum lines to make sure that you don't have a vaccum leak.
Is the battery in good shape?
As mentioned, cleaning the Idle Air Control valve (IAC) with WD-40 or SeaFoam 'Deep Creep'
Remove the IAC.....hold it so that you can spray into it....and have the fluid run out.....rinsing out dirt/crud, leaving a lubricating film.
The above is all good to go over before winter sets in.
A good inspection of the IMRC system (3.8L engine only), the 1998 still uses vaccum driven actuators to pull the IMRC to the CLOSED position.
If 1 or more of the IMR shafts is not closed fully, it can cause low RPM issues.
Springs pull the IMR shafts OPEN when there is no vaccum (like when the engine is not running) and vaccum pulls the IMR shaft to the closed position when you start the engine.
The PCM controls the IMRC vaccum solenoid to have them open/closed.
With no CEL, these are the things that I would check out first.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 11-07-2009, 10:41 AM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
Checking the fuel and air filter is a very good idea.
It happens also when you accelerate on neutral? Or only when you're driving?
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 11-08-2009, 04:50 PM
As suggested, I cleaned IAC but no effect. Since the problem is very reproducible, I pulled vacuum lines one at a time (whatever I could find). By luck, when I pull out the vacuum line on the top of EGR (I think it is a vacuum line) and the problem disappeared. At least I can say the problem is the EGR system… I’ll try to take it out and clean it as many of you have done. Will let you know if I succeed. BTW, the roughness happens while in neutral as well.
Old 11-15-2009, 08:11 PM
An update..
I took out the EGR and it looked ok.. no blockage and the valve seemed to open and close ok. I cleaned it anyway and put it back… still the same problem. The next one was the pressure sensor sitting right next to EGR (I believe this controls the EGR??). It is replaced but did NOT fix the problem. Put the old one back after cleaning the two tube holes.
I was about to give up but I remembered reading about cleaning the small holes in the in the intake manifold, which tend to get clogged up. I un-tightened 12 screws, lifted up the cover just enough and indeed the four holes near EGR side were clogged up. I tried to take the cover out, but something was holding it in the back side. I lifted up the cover some more such that I could put my hand in and unclog the holes. I used a long screw with a sharp end with a long string tied in case it falls into a big hole… With the unclogging, the problem is gone. It took about five hours for the whole operation. It was not particularly difficult.
Old 12-07-2009, 06:43 PM
3d914's Avatar
3d914 3d914 is offline
SamNovice,
So did cleaning out these holes resolve the issue, or does the problem still exist?
TIA,
Gerard
74-914 2.0L Ravenna Green
3D914 ---- 914 Parts
[email protected]
"It is as if the world we perceive through our senses - that whole gorgeous and terrible pageant - were the breath-thin surface of a bubble, and everything else, inside and outside, is pure radiance. Both suffering and joy come then like a brief reflection, and death like a pin." - Stephen Mitchell
