Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-05-2009, 07:47 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Super-AFC II in 97 GSX
I am trying to hook up this S-AFC II into a friends 97 GSX, but I am a little lost.
I got the RED (power), BROWN (ground 1) and BLACK (ground 2), the GRAY (throttle), PINK output and ORANGE input (Airflow) wires connected.
I am having problems with the GREEN (rpm) wire - the manual says it should be connected to PIN 8 (in the 12-pin connector) - well that pin doesn't exist, it is just an empty slot.
The PURPLE (knock), it is also suppose to be connected to PIN 8 (in the 22-pin connector) and it is just an empty slot as well.
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 11-05-2009, 10:13 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Super-AFC II in 97 GSX
I know this is going to sound weird, but look at the connector as if it was in a mirror and see if the wires match up then. The pin layout for my 95 420a ECU was totally backwards.
Also, make sure it's the right harness.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 11-05-2009, 10:33 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
unless im mistaken you wont be able to see knock with the afc on a turbo dsm anyways so you might as well leave that wire unhooked anyways. As far as the rpm signal goes you shouldnt have a problem finding it. It has been so long since i have looked at a dsm ecu layout i wouldnt be able to tell you anything. Try vfaq.com i think there is an informative write up about afc installation there.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 11-06-2009, 07:59 PM
Well the connectors aren't shown backwards, be cause the other wires are right where they should be.
I checked on VFAQ.COM and none of the links for the AFC install work. but I checked the pinouts, on VFAQ.com, and it shows the same thing except they are not numbered the same (1-92), in the manual they are numbered 1-?? (depending on the number of wires in the connector) for each harness. none the less that wire is missing and I am lost....
Old 11-08-2009, 09:21 AM
anyone ever hook one up in there 2gen eclipse?
