Old 11-05-2009, 01:56 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Time for new exhaust
Time for the 2.5" exhaust to be replaced. I believe its causing the power to drop off in the higher rpms. Also still cant get ride of these damn exhaust leaks at the downpipe. So I have decided to replace everything.
Enjoy.
3" Catback SS
3 90* mandrel bent 3" SS
SS flex section
SS 3" vband
vband adapter for the turbo
td06 exhaust wheel with T3 housing
SS tubular exhaust manifold
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-05-2009, 02:03 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Time for new exhaust
Sexiness. Now I really want to work on mine right now.
Looks like you won't have a problem with wastegate that I did.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 11-05-2009, 02:23 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Everything looks nice, though I still don't trust the manifold. What wastegate is that mani designed for and which one do you have? Mine is a TiAL 38mm and it has the round 2-bolt flange.
Also, I'm no expert on turbos. What was the reasoning of switching exhaust wheels and housings? Better spool? Or better top end flow im guessing?
What brand is the exhaust and manifold? XS Power?
I wasnt aware that they made v-band adapters like that, thats cool. When do you expect to have everything installed?
P.S.,
Dave: your a dick
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 11-05-2009, 02:37 PM
Holset powered 420a
Manifold is obx and designed for a 40mm wastegate. Thats the 4 bolt flange, I will be using a 38mm so Im going to cut that entire piece off and weld it facing the other way and also changing the flange to a 38mm. The T3 exhaust housing is bigger and will flow much better, also the td06 wheel is much bigger and will flow a lot better in high rpms. The td05 wheel becomes a restriction once boosting 20+ psi. With new injectors I plan on pushing this turbo to about 28psi so the smaller wheel had to go.
Planning on having it installed in the next few weeks. Over thanksgiving holidays at the lastest.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-05-2009, 09:59 PM
steviek's Avatar
steviek steviek is offline
that looks great. Can you snap another picture of that muffler though?
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 11-06-2009, 09:50 AM
Holset powered 420a
Sure which part do you want to see?
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-06-2009, 05:44 PM
ned032002's Avatar
ned032002 ned032002 is offline
That looks hot!! How soon will you have it all installed? Any pics of the car as it sits?
Old 11-06-2009, 07:43 PM
Holset powered 420a
Hopefully next weekend I will have it on. Ned Ill snap some new pics. The eclipse needs to be washed first, its pretty dirty
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-07-2009, 08:43 AM
david-b's Avatar
Dave is THAT guy
You think yours is bad... should see how much dust mine has on it from being the garage for so long. Can't see out the front window... except for where I tagged it
75 Monte Carlo
Old 11-09-2009, 06:23 AM
steviek's Avatar
like looking down the tail pipe. t looks like the hole gets wicked small.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 11-09-2009, 08:12 AM
david-b's Avatar
Dave is THAT guy
That's the silencer. They pop out.
75 Monte Carlo
Old 11-09-2009, 11:27 AM
What exhaust do you run steve?
Caleb
vanilla gorilla
Old 11-09-2009, 02:45 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Weld some bracing under the ports on the mani!
Kris
2012 Genesis Coupe 2.0t
Old 11-09-2009, 03:48 PM
Holset powered 420a
You cant really see them but there is extra support welded to the top of the runners
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-09-2009, 09:45 PM
steviek's Avatar
its a custom exhaust. Really Really well done only cost me 400 bucks with all mandrel bent galvanized aluminum piping. full 3 inch.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
