Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 11-04-2009, 09:55 PM
palomba16 palomba16 is offline
86 MC SS timing question
I tried to set the timing to 0 and it ran very bad and stalled. The only way it runs decent is to advance it well ahead of the timing marks. To set the timing on this 5.0 is there anything I must disconnect first? There is no vacuum advance. Reply to [email protected] if you can.
Thanks
Old 02-15-2010, 12:17 PM
rodgerturner rodgerturner is offline
Re: 86 MC SS timing question
Timing on a stock 4th Gen (83-88) SS is 6* BTDC. The distributor advance is computer controlled so you do need to fist disconnect the 4-pronged connector coming from the Distributor (should run along the drivers side valve cover). You only need to set the initial timing.
