Go Back   Automotive Forums Car Chat > Citroen > Xantia
Old 11-04-2009, 04:59 PM
addplant addplant is offline
Xantia's internal fan not working
HI the fan on my Xantia goes on and off when it like's can any body help
some say the fan is on the same connection as the back demister but my demister work's OK all the time
please help as it's starting to get very cold in the morning now
Dave
Old 12-14-2009, 04:11 AM
Tan T Tan T is offline
Re: Xantia's internal fan not working
I have owned two xantias in the last 9 years and none of them had a good fan control switch. I have to say that I have managed to work out how to position the slider switch. When its very hot ie summer time - position the slider to the extreme left(AUTO) and on that position the fan kicks in automatically when the inside of the car gets hot.Also make sure you have selected a comfy temperature on the temp slider. When the temp drops in winter you have to position your fan slider near or at max position again with a temp of about 22C selected. The fan in the xantias seem to have 0 and Max only with no in-between. However if you tweak the slider slightly down from max you may just get the desired fan speed. Hope this helps.
