Old 11-03-2009, 10:31 PM
kkfos1975 kkfos1975 is offline
Lost 2nd gear and overdrive
I lost my 2nd gear and overdrive in my 1995 chevy silverado today. It has an electronic tranny. any idea's? 1st drive and reverse work.
Old 11-03-2009, 11:46 PM
2000CAYukon 2000CAYukon is offline
Re: Lost 2nd gear and overdrive
2nd Gear and 4th (Overdrive) both have the 2-4 Band applied. If you lost both of these gears, the 2-4 Band is slipping. Tranny needs to be removed and rebuilt to repair this failure.
//2000CAYukon
Old 11-03-2009, 11:48 PM
//2000CAYukon
Could it just be the solinoid?
Old 11-04-2009, 07:58 AM
j cAT j cAT is offline
with a transmission this old and past reports of failures this would be a rebuild job..
what are your transmission fluid / filter maintenece intervals ...?
did you just purchase this vehicle? what does the fluid look like ?
Old 11-04-2009, 08:09 AM
maxwedge maxwedge is offline
A990 racer
A scan with a trans function would reveal whether the solenoid is active, but j cAT's advice is correct.
Old 11-04-2009, 03:25 PM
2nd and 4th do not share the same solenoid.
For 2nd, the A solenoid is OFF, B is ON.
For 4th, A is ON and B is OFF.
When it is suppose to shift to 2nd, does it feel like it goes into Neutral or does it stay in 1st?
//2000CAYukon
Old 11-04-2009, 08:54 PM
transman618 transman618 is offline
If you have lost 2nd and O/D but reverse is good then the issue is with the 2/4 band or band servo. The servo could be leaking or the band strut is broken. I would check the pan for debris. This is not an electrical problem.
transman
GM MASTER TECHNICIAN
SR. TRANSMISSION BUILDER
