Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '04+
Old 11-03-2009, 12:01 PM
RyanCSpgs RyanCSpgs is offline
Lightbulb VW Jetta 2004 2.0 Several Engine Codes
Asking for a little troubleshooting help. These codes have come on consistently after clearing and then driving again. It started with the vehicle having major lurching hesitation during acceleration from a stop and in 1st gear. I removed and inspected the MAF Sensor, which had no obstruction or other obvious problems then the engine codes began immediately...
The codes:
These include P0445 - EVAP Emissions, P0137 - O2 Sensor, P0141 - MAF Sensor, P0102 - Mass Air Flow. There are 3 other lights like P2400 (no idea what that is)
Anything in common problem between these components? The car has over 60K miles. Thanks
Old 11-05-2009, 08:10 AM
Re: VW Jetta 2004 2.0 Several Engine Codes
Just in case anyone is curious, I found the problem. While troubleshooting the MAF power (prior to engine light and codes) I created my own secondary problem; I had blown the 10A fuse (#43) by incorrectly testing the voltage. I'm obviously not a mechanic and made a mistake that added to the Joy of fixing a vehicle. The original lurching and hesitation problem is gone too...gotta love cars that strangely heal themselves!!
The Following 2 Users Say Thank You to RyanCSpgs For This Useful Post:
cosmonaunt (10-10-2016)
Old 10-10-2016, 02:25 PM
cosmonaunt cosmonaunt is offline
Talking Re: VW Jetta 2004 2.0 Several Engine Codes
Thank you!!
I had a list of codes and had to rev the engine to start it up. it was just a fuse. turned a $150 dollar fix into a $10.
I still had codes and had to clear them. Going to drive around and see what comes back up
If anyone is interested these are the codes:
P0141 - O2 B1S2
P2181 - COOLING SYSTEM PERFORMANCE
P0130 - 02 B1S1
P0031 - 02 HEATER CONTROL LOW B1S1
P2400 - EVAP LEAK DETECTION PUMP (OPEN)
P0445 - EVAP PURGE VALVE CIRCUIT SHORTED
P0037 - O2 HEATER CONTROL LOW B1S2
P0418 - SECONDARY AIR INJECTOR RELAY A MALFUNCTION
P0102 - MASS OR VOLUME AIR FLOW A CIRCUIT LOW INPUT
I know not all of them where the cause of that bad fuse, but it definetly helped. going to replace the O2 sensors soon..
