Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-03-2009, 09:22 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question Radiator hoses
Thinking I want to swap out the silicone radiator hose for something better because of the manifold. Are all radiator hoses the same diameter?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 11-03-2009, 09:33 AM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Re: Radiator hoses
I dont think so, Ive noticed on bigger engines the hoses are slightly bigger. Also, the shaping is very different.
When I had to replace one of mine because the clutch arm rubbed a hole in it, I ended up getting the wrong hose but I was lucky enough to be able to zip tie it lightly to the side to avoid both a pinch point and the clutch arm again.
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 11-03-2009, 10:30 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Radiator hoses
I would probably just wrap it in some exhaust wrap for now. I'm not sure what else you can do since its touching right at the tstat housing.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-04-2009, 07:10 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: Radiator hoses
Heat-reflective tape.
Kris
2012 Genesis Coupe 2.0t
Old 11-04-2009, 08:51 AM
david-b's Avatar
Dave is THAT guy
Re: Radiator hoses
I'm not familiar with the tape. I've seen it, but never used/heard anything about it. Lando, don't know if you seen my project thread, so I'll post the pic here...
You can kind of see that the radiator hose is touching the manifold. Would the tape protect it at all?
75 Monte Carlo
Old 11-04-2009, 08:56 AM
Re: Radiator hoses
Yeesh. Not gonna help that.
Kris
Old 11-04-2009, 09:34 AM
david-b's Avatar
Dave is THAT guy
Re: Radiator hoses
That's why I'm thinking some kind of metal-covered radiator hose. But still wondering if it'ss get too hot and melt it. I don't know how much heat 4-layer silicone can take.
Think if I bend some sheet metal between the 2 and around the hose it may disapate the heat some?
75 Monte Carlo
Old 11-04-2009, 11:26 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Radiator hoses
You be SOL.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 11-04-2009, 07:21 PM
ned032002's Avatar
ned032002 ned032002 is offline
Re: Radiator hoses
Words wisdom are anazing Brian
I've looking into getting some better hoses but I don't want to spend a fortune, any suggestions? I'm not jacking this thread it relates to your issue in a way.
+1 on the piece of sheet metal around the hose. I don't know of anything else to use to protect the hose. I think once you get to temp you will start smelling burnt rubber. My :2cents
Old 11-04-2009, 07:49 PM
Holset powered 420a
Re: Radiator hoses
Wrap the hose in exhast wrap. If you put metal there its going to just tranfer the heat into the rad hose to. The wrap will cut down on the heat a lot. I know its tight now but wrap the hose with as much wrap as you can fit there. The more layers the better.
98 Eclipse GS Turbo
2001 BMW 325i - DD
