Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 11-02-2009, 06:46 PM
H_civic66 H_civic66 is offline
2000 silo radio
Ok I have searched and cant find any thing, well I want to install a new radio (cd's dont play anymore) and was wondering if I could still use the steering controls? Was thinking about a double din with dvd so I would also like to know if I could hook that up too the video system? Thanks....
Old 11-04-2009, 06:33 PM
Re: 2000 silo radio
Ok I have been a member of many forums, That being said does noone answer on here? Just a bit confused.
Old 11-04-2009, 07:19 PM
roadrunner2 roadrunner2 is offline
Re: 2000 silo radio
More likely noone has any idea how to help.
That includes me. Sorry.
The problem with doing nothing is not knowing when you're finished.
Old 11-08-2009, 02:53 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: 2000 silo radio
Exactly. There have been 53 views of this thread and it's apparent that the question asked might be difficult to answer. When I have been in a similar situation I have always replaced the radio with a used one the same as what was currently in the vehicle. I'll send a PM to the Mod over in the car audio forum to see if he may have an answer.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 12-01-2009, 09:46 AM
Milo2001 Milo2001 is offline
Re: 2000 silo radio
Some stereos have the option to reconnect to the steering wheel options. Others do not. Your best bet is to contact a reputable stereo place, like Crutchfield.com, and explain what you are going to do. There are wire connectors for the steering wheel controls that are needed to bridge between the steering wheel and the stereo. I've already researched this a while back for my Grand Prix. Being GM it should be the same.
Old 12-01-2009, 12:05 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: 2000 silo radio
PAC and PIE make steering wheel control interface boxes. You splice into a couple of wires in the harness, then plug the other side of the box into the headunit. The headunit should have a note about it being steering wheel control compatible. Be advised, the controls will NOT be as instantaneous as the control on the HU itself - it will have a slight delay.
Here is PAC's website with install intructions and which modules work with what
http://www.pac-audio.com/swixprogram...rogramming.asp
Old 12-02-2009, 08:35 AM
Re: 2000 silo radio
Thank you for your replies. Ill keep you updated.
