Old 11-02-2009, 08:57 AM
f100240 f100240 is offline
Can Master Cylinder Be Bad Without Leaking?
I've replaced the front pads, the rear brakes and wheel cylinders, and bled the system. I still have the same symptoms: the peddle seems good, but the stopping power is bad and when pushed hard the peddle is spongey. The vacuum is good, and there are no leaks from the master cylinder. Can it fail internally and cause problems that are not readily apparent?
Thanks.
f100.
Old 11-02-2009, 10:26 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Can Master Cylinder Be Bad Without Leaking?
Yes, Especially after doing a brake job on a higher mileage vehicle and pushing the pedal all the way to the floor to "pump up" the pedal. The debris that accumulates in the bore settles in the part that rarely gets used. Run the seals through that debris and they can be junk after that. Its a 50/50 thing. Sometimes there isn't a problem and sometimes there is.
A similar feeling can happen until the pads are seated into the rotors.
Old 11-02-2009, 08:41 PM
Woodie83's Avatar
Woodie83 Woodie83 is offline
Bad calipers or hoses can do the same thing.
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
