Old 11-01-2009, 10:00 PM
fitenfire4life fitenfire4life is offline
Smile 2001 GTP Headlight problem????
I have a 2001 GTP, Headlights do not work, taillights, parking lights, and fog lights work great! Would it be the circuit breaker in fuse box?? Terimals look fine on breaker..
Old 11-02-2009, 08:46 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: 2001 GTP Headlight problem????
You could swap it with another relay from the fuse box to text it out.
Sounds like you will need a multi-meter and a wiring diagram.
Do your high beams work? How about your brake lights (brake, not tail)?
Sounds like it could either be an issue with the headlight switch, or the multifunction switch to me. But its better if you do some tests to track down the issue.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
