will motor out of 2003 implala work
yes i was wondering if the motor out of a 2003 chevy impala will work in my 1997 chevy venture van
Re: will motor out of 2003 implala work
I have a CHANGE SHEET for 2003: Quote:
When you read all the changes and improvements just for '03 most of them not necessary, it's a wonder why they still didn't fix the lower intake mnaifold gasket issue?
It looks like you'd probably need the wiring harness and PCM from the '03, and reprogram the PCM for a car swap to make it work. |
Didn't they address this issue with the release of an updated intake gasket in July 2002? The main issue was the design and materials of the gasket itself. I haven't seen any real issues after 2003 with the OEM gaskets used like their predecessors had.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
No they didn't fix it by the '03. I replaced one on an '03 3400 and it was the same old gasket. Maybe they fixed the gasket by the very late '03 to '04 model, but still they made changes to other engines parts several times before '03 and '04, but never fixed the gasket. We are talking about 10 years with that same old gasket while other updates were done to the engine. It doesn't make a lot of sense and it's not really acceptable IMO.
More than likely that '03 you did was probably made in the early production cycle for that model year. Sometimes it takes awhile for updates to trickle down and my guess is GM probably had some old version gaskets left over and rather than scrap them, they used them figuring they would just get replaced further down the road. I know a couple guys who worked the assembly lines and have some real interesting stories about what goes on/went on while they were there. I haven't seen any '03+ in the shop needing gaskets so I gathered the issue was fixed beyond the 2002 model year. ( I have seen some '02 and before in for a second set of LIM, which also is unacceptable.)
OP, did you ever try it? My uncles says the fuel rails will have to be changed as well as some of the externally mounted hardware on the motor. But it would be a guess at that. Would be a good source for replacement motors tho....
1997 Chevrolet Venture SFI 3.4l Auto 249k 2006 Chevrolet Malibu Maxx SFI 3.5l Auto 81k http://www.s10forum.com/forum/attach...nsor-chart.gif |
Why are you changing the motor? Bad Cam Bad crank? the blocks between the 3.4 and the newer 3.1's are pretty much the same and if you are creative you can make just about any of them work.
PS: GM has not made any good changes to the lower intake gaskets on that block I just changed a leaking lower intake on an 05 G6 with the same stupid plastic gasket. |
