Old 10-31-2009, 12:33 PM
clyde752 clyde752 is offline
Post beefing up rear springs for towing, too much sway
What can I do, Install, in the rear suspension to stiffin it up? I bought a larger travel trailer, ( within tow capacity), use a sway bar but I still don't like the feel on the highway. It doesn't seem to do it towing with a truck with leaf spring but does with coils. Any thoughts?
Old 10-31-2009, 04:16 PM
maxwedge maxwedge is offline
A990 racer
Re: beefing up rear springs for towing, too much sway
What does it do? Sag, sway, wander?
Old 11-01-2009, 10:53 AM
Jethro Jethro is offline
Send a message via AIM to Jethro
if you have the cheaper rated tires you need to step it up to the more aggressive goodrich all terrain tires that load max 2500 lbs per tire. I used to have that problem with the michelums xlts. Too soft and not good for towing. My tires now hold 65psi air. I found that when you start to sway at 60 it will stableize by jerking the wheel left right from 8 to 10 a few times. Just get a bigger truck if this dont work. Mine is rated for 6200 tow capacity, not all tbs are rated for that.
2002 LT Trailblazer 4x4 One of the first of this kind on the road
2003 3500 LT Silverado 4x4 ext cab
2006 Heritage Softail HD FLSTI
