Old 10-31-2009, 11:18 AM
Mariobellavance Mariobellavance is offline
Question van won't start
Hello I have a 1999 windstar with a 3.8, It won't start unless I depress the gas peddle when I release the gas it will stall.
Could it be fuel filter
Old 10-31-2009, 12:37 PM
bdahl385's Avatar
bdahl385 bdahl385 is offline
Re: van won't start
Look at cleaning the IAC (Idle Air Controller) valve... The symptoms could point at this and needs to be serviced from time to time. http://leckemby.net/windstar/windstar02.html
You could also have a bad spot on the TPS (Throttle Position Sensor) and the PCM is not getting a good reading with your foot off the pedal. Does the van run okay as long as you depress the gas a little?
2000 Windstar SE 3.8L 125k miles (mine)
2006 Hyundai Sonata LX 3.3L 108k miles (wife's)
2013 Hyundai Elantra GLS 21k miles (daughter)
Old 10-31-2009, 08:13 PM
wiswind wiswind is offline
Re: van won't start
A sticking IAC is a common cause of this problem......try cleaning it with WD-40 or Seafoam "deep creep".
The IAC (Idle Air Control) does as it name implies....controls the air into the motor when your foot is off the accellerator.
The PCM uses this to control the idle speed.
If it sticks, it cannot open and your engine will stall due to lack of air.
Cleaning usually solves the problem......and is cheaper than replacing it.
I still have my factory original IAC on my '96 with 216K miles......it stuck once in a while a few years ago......cleaning as I mentioned solved the problem for me
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 10-31-2009, 11:20 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
Re: van won't start
To check if the IAC is damaged,
disconnect the connector from the IAC valve,
turn the key to ON (without starting) and check voltage between the 2 wires of the connector. It should be between 10.5 and 12.5V (if the battery is charged).
If it's good, it indigates that the PCM is not the cause of the problem. Turn key to off.
Then measures the resistance between the 2 terminals of the valve (not the connector). It should be between 6 to 13 ohms.
If not, replace the IAC valve.
If it's good, measure resistance between any of these terminal and the IAC case ground.
It should be minimum 10kohm. If it's less, replace the IAC valve.
To test the Throttle position sensor (tps), connect the voltmeter between GND and signal pin of the TPS connector (without disconnecting the harness). The signal is positive.
Turn the key to ON. It should be a little bit less than 1V. If it's less that 0.75V, replace the TPS.
Check also the voltage between reference pins and GND, it should be 5V. This is the TPS connector:
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
