Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 10-30-2009, 04:21 PM
phipps phipps is offline
Bleeding Master Cylinder/ABS System
I have a 96 Ford Explorer that blew out a rear brake line. My SIL was driving it and proceeded to run the master cylinder dry.
I have replaced the brake line and bled the lines, but the pedal is still going to the floor and is very soft. I suspect there is air either in the master cylinder or the ABS system. How do I bleed those?
Thanks,
Gary
Old 10-30-2009, 06:32 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: Bleeding Master Cylinder/ABS System
The master cylinder should be filled with fluid once bled. The only way the ABS can be bled is with a device that can command it to.
I don't believe air in the ABS system will cause the brakes to be soft, however. Did you bleed the lines at all 4 wheels?
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 10-30-2009, 07:05 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
You probably still have air in the lines. I was amazed how long it took to bleed the brakes and get all the air out. I'm a firm believer in Speed Bleeders after a few times trying to purge a system of air. On one of my vehicles Speed Bleeders were not locally available so I tried the Mity Vac route. It was A LOT of pumping, but did the job. I never really liked the feel of the pedal though, and eventually tried the $20 (on sale) bleeder tool from Harbor Freight. It never had such a great pedal feel.
-Rod
