Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 10-30-2009, 07:04 AM
Jim woodruff's Avatar
Jim woodruff Jim woodruff is offline
Brake bias panel
Has anyone installed a brake bias panel in there RA or WC cars?. I would like to keep the braided hoses or steel tubing on the inside of the fire wall. Looking for some constructive ideas. I would like to make plug and play.
Old 11-02-2009, 11:43 AM
Panoz26's Avatar
Panoz26 Panoz26 is offline
Re: Brake bias panel
Jim,
I am surprised you don't have this - please excuse the disaster - I am currently rewiring everything (and will be doing some winter cleaning/painting too).
the Blue knob of course is the bias knob, the black cable leads to the rear of the brake cylinders - if you move yours out of the cockpit, please send photo's - coz I really hate where they are mounted:
Devin - (aka Panoz26)
Formally WC Car # 26, Red
Now = WC-GT2 # 211, Black
Old 11-02-2009, 12:09 PM
panozracing's Avatar
panozracing panozracing is offline
I think Jim is asking about the brake bias gauges not the actual knob?
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 11-02-2009, 01:19 PM
boothkc boothkc is offline
We put these http://www.pitstopusa.com/ShowImage....s/LON44136.jpg in the braded lines just T into the brake system and we mounted the panel on the far left of the dash. Helps to see how much real force you are generating prior to lock up etc. Also easy to see if something is losing pressure.
Kevin
Old 11-02-2009, 01:45 PM
Kevin
Kevin, Is there room to tee into it on the cockpit side of the firewall? I know I can get to it on the engine side. Thanks for the help My car is not at home to check.
Old 11-02-2009, 01:51 PM
Panoz26's Avatar
Ah, sorry, did not really get that - but, now I do :o).
i like the idea and will probably do the same.
Old 11-02-2009, 01:52 PM
sorry after looking at the picture of the Willwood master cylinder there is plenty of room and a piece of cake. Thanks for the photo. I now can order the fittings.
Old 11-12-2009, 04:07 PM
I have installed the Longacre bias gauge panel and it was very easy. Plug and play with the correct fittings. Took 15 mins. If anyone wants the bill of material just let me know. Early morning runs should be a breeze now with out front lock up.
Old 11-12-2009, 06:20 PM
I have one to install in my car...we had the shop do the other car...I hate working tight up under the windshield. Was it hard to get the air out of the lines? I bought the gauges from PAD with the fittings so I hope I have all the right peices.
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 11-13-2009, 07:06 AM
The Longacre unit has the bleeds built into it and was very easy to bleed. There is plenty of room if you have the correct fittings and hoses. I put the brake bias panel on the switch panel and not on the dash like Pad, This way you can remove the dash with little effort. Before you start check your hoses to make sure they flow I had one that was blocked and had to make a quick trip to Summit.
Old 11-13-2009, 07:35 AM
so you had to use new longer SS lines? Can you take some pics?
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 11-13-2009, 07:46 AM
Give me an e-mail address and I will send them to you by Monday. I purchased 36" lines from Summit. Fast and easy. I wish every thing went that well.
Old 11-13-2009, 07:48 AM
[email protected]
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
