Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 10-29-2009, 11:09 PM
WMX267 WMX267 is offline
Compressor cycles too often when using the heater
Just a quick question regarding my compressor. When I'm using the heater, the compressor cycles a little too often. I understand that this is a good indication that I have a low level of refrigerant when using the A/C, but is it supposed to even kick in even if I'm heating the cabin?
I got a reply from another site saying that if i'm using the defroster, there is a need for the compressor to kick in to balance pressure. Can someone validate this? I have not tested it thoroughly with the different settings as it didn't occur to me, but I do know that the compressor seems to cycle more in defrost, than when on A/C.
I have a 97 Explorer V6 push rod.
Old 10-29-2009, 11:40 PM
inafogg inafogg is offline
Re: Compressor cycles too often when using the heater
if you are selecting defrost/ac mode the A/C is used other than that the compressor should not run
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 10-30-2009, 06:30 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
If the compressor is running in the heat mode, you have a problem in the system. Have the switch tested to be sure it is working properly.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 10-30-2009, 07:35 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
According to the factory service manual, the A/C compressor will be engaged during the following modes:
  • A/C
  • Max A/C
  • Defrost
  • Floor/Defrost
  • Panel/Floor
Of course this depends on the ambient air temp. If the ambient temp is below 32 degrees F the compressor will not engage to prevent condensation from freezing.
It will be disabled when the following modes are selected:
  • Off
  • Vent
  • Floor
If the clutch is cycling rapidly when one of the modes is selected where the clutch should engage, the system is either low on charge, overcharged, or the clutch is weak (field coil, gap too large, etc.).
-Rod
