Old 10-29-2009, 06:56 PM
actmach actmach is offline
engine problem
So
Today i drove my car to work mostly freeway (91 vr4) got off freeway and when i went up to the stop light it had dropped a cylinder after work I popped the hood and gave the engine a quick visual checked wires cables hoses started it up and miss was still there by the time i got home it had no power at all it would still idle but it Rev's real slow and sounds like it is missing on at lest 2 maybe 3 cylinders dose anyone know what causes this please help the stock turbo gage reads almost no boost
Old 10-29-2009, 07:34 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: engine problem
Likely have a boost leak.
Old 10-30-2009, 08:15 PM
Johnny3000 Johnny3000 is offline
Re: engine problem
A vacum leak is likely but before I started a endless search of vacum hoses I would check plugs for spark if you don't have it and have a recent tune-up then it's probally a bad ECM, but if you have good spark then stealthy is probally right (might be a bad injector aswell)
Old 10-30-2009, 09:50 PM
Re: engine problem
Well today i spent most of the day back flushing the fuel filter and cleaning the front injectors put it back to gather ran OK for about 5 min
then it had the same problem now its worse i am thinking some rust in the gas tank or something in the tank i am going to completely flush the tank and clean the injectors again what is the best way to clean out the injectors let them soak in ? or spray them with ? could someone give my some advice on this thanks
Old 10-31-2009, 06:08 AM
judepeter judepeter is offline
Re: engine problem
have pajero petrol replaced plugs and leads started ran for 5 min put cover on hasnt started since 2 wks ago computer says crankshaft sensor problem
peter
