Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 10-29-2009, 01:16 PM
b_barlan b_barlan is offline
no brake, reverse lights or blinkers
My 98 Sierra has no brake or reverse lights, nor does it have rear blinkers. Its not a fuse or bulbs, and they quit working at different times. Any suggestions? Im gonna try the brake light switch
Old 11-01-2009, 10:44 AM
pies pies is offline
Re: no brake, reverse lights or blinkers
had the same problem with an 03, look at the back of the truck between the frame rails and see if there is a module, check the plugs on the module, the 03 one plug was loose. if no module, and all lights don't work, then trace wiring, you have a ground problem some where.
Old 11-03-2009, 03:28 AM
gilbert2121 gilbert2121 is offline
Also try tightening the check valve on the brake booster.
I have NOOO idea why but that solved the same problem on my 89.
