Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 10-29-2009, 11:16 AM
94caprice25 94caprice25 is offline
94 caprice. loss of power when its raining
I have A 94 Caprice 4.3. Every time its raining real hard , My check engine light comes on and the car will have a loss of power for a second and be fine for A minute then it will do it again. This will repeat until its done raining or the next day.It doesnt lose complete power, its almost like its missing. This is getting anoying please help! Thanks
Old 10-29-2009, 05:03 PM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
Re: 94 caprice. loss of power when its raining
The only thing i can think of is your plug wires are getting wet or they might need to be replaced due to water getting in cracks if they're old wires
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 10-29-2009, 06:39 PM
j cAT j cAT is offline
since this is a 1994 the inner fender should have a black fiber material that extends down to reduce water splashing on the engine from the front wheels if this is broken or missing this can get water into the plug wire connections at the spark plugs ..If no dielectric grease was used when the wires/plugs installed at the plug boot ends the water eats away at the silcone centre wire conductor..then the missfiring ...
Old 10-29-2009, 10:07 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Sounds like water is getting in the OptiSpark distributor.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 10-29-2009, 10:44 PM
evildragon evildragon is offline
Yea, its opti.. mine does the same..
all on the ls1lt1.com forum with the lt1 pretty much get the same too.
dont get the SES though.
My one and only car!
1994 Chevy Caprice Classic LS
L99 Engine
