Old 10-28-2009, 09:08 PM
dagan06 dagan06 is offline
88 F250 351 Windsor head gasket
Are these hard to change? i've never done something like this and thought this truck might be a good one to try it on i've done fuel pumps, water pumps, timing chain/belt ect... so i know my way around a car just wanting to know if this might be to far over my head. any tips or sugestions or should i take it to a shop?
Thanks in advance
Old 11-14-2009, 04:49 PM
dfordski's Avatar
dfordski dfordski is offline
Re: 88 F250 351 Windsor head gasket
Thanks in advance
You have a blown head gasket? From overheating? wikipepia!
"Saving the World......One Ford Truck at a Time!"
Old 11-16-2009, 07:44 PM
denisond3 denisond3 is offline
I have a 91 F350 flatbed with a 351 in it sitting in my yard. It has a rod-knock audible even with cold oil. I promised the owner (an in-law) I would fix it - so am beginning to dismantle stuff so I can pull the engine out. We think the truck has about 285,000 on it, so I figure it will need 'the works'; valve job, pistons/rings, bearings, crank regrind, etc.
It has individual injectors, but dont even know if its a 351W or "C". What would be a good manual to obtain?
If I knew what transmission it has (automatic w overdrive) I would try replacing the clutch packs and bands in that too.
This thing would be lots easier to work on if I could unbolt the front fenders and pull off the 'front clip'. Thats what I did that when I fixed up the last Ford V8 I worked on - my 52 Ford F1 with flathead V8. If not I hope I can at least unbolt/remove the front radiator/condenser support - so as to reach stuff better, and not have to raise the engine so much to get it out. (The mesquite tree that is providing the shade has a low limb.)
Old 11-29-2009, 11:58 AM
birar birar is offline
should be a 351w im pretty sure they stopped putting the 351c in the late 70s early 80s
Old 02-14-2012, 08:38 PM
jajajm jajajm is offline
That is the 5.8 liter (same as the 351W
