Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 10-28-2009, 03:04 PM
swiman1219 swiman1219 is offline
Need help bad!!!
i have a 2004 gmc sierra 181,00 miles z71...when i am going around 35 mphs there is a noise in my front end or under my truck somewhere that sounds like metal grinding or something is loose and its contiunually getting worse please help anything would be nice
Old 10-28-2009, 06:55 PM
maxwedge maxwedge is offline
A990 racer
Re: Need help bad!!!
Welcome to AF, reallistically no one can get a handle on this from their desk. Check for loose shocks or any worn loose steering/suspension components or wheels and wheel bearings, all basic stuff for what you are experiencing.
Old 12-02-2009, 10:37 AM
ebedsilva ebedsilva is offline
I have a similar problem in my 01 z71 but it was only in first gear. when the tranny would shift to second the sound went away. At first I thought it was the u joints so i changed all of them (front and rear shaft). But that didnt help much. Also I changed all the fluids, transfer case, front and rear diff, tranny I had just done recently about 3 months ago. I thought that would fix the problem too but nothing. However what I did learn is not to put tranny fluid in the transfer case. Its a special blue fluid that I had to buy from the dealership ($9/qt) which looks really cool. I wanna say is GM Auto trak but I can't recall for sure.
2001 Sierra SLT Ext Cab Z71
2000 Malibu LS
Old 12-03-2009, 05:24 PM
pies pies is offline
drive down the road and swerve from left to right, if the pitch of the grinding noise changes, then you have a wheel bearing failing. to figure which bearing it is, drive on a road that has a long curvein it. if you turn to the right on the curve on the noise diminishes then it is your left wheel and the oppisite for the other way.
