Old 10-28-2009, 12:19 PM
joheir joheir is offline
Charging system issues
I have a 2000 ford windstar, the battery light on the dash came on awhile ago, and the van soon wouldnt start. I put a borrowed battery into it ... but needed to jump it to get it started, then i tried the "classic diconnest the battery method" to test and see if the alternator was the issue.... it appeared that it was, as the van stalled out. I bought and installed the new alternator, but the problem was still existent, however... when the battery was disconnected the van still ran... so I bought a new battery, my issue remains... the battery light on the dash comes on. I still have a weak charging system. Does anyone have any idea what else could be causing this issue? thanks in advance for your much needed help.
Old 10-28-2009, 10:45 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
Re: Charging system issues
Welcome to the AF Forum!
When engine is running, check voltage on the battery, it should be at least 14V. If not, you have a problem.
When engine is running, check if you have the same voltage on the B+ (positive) connection of the alternator and the positive of the battery. If you have a even a slight difference, it means that you have a bad contact.
I think you may have a discharge when you car is turned off. Maybe a short-circuit somewhere. Disconnect the + terminal of the battery and connect an amperemeter between the battery and the cable. If the current is more than 50mA, you have a short somewhere.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
