Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 10-28-2009, 06:58 AM
bheston bheston is offline
2001 Dash lights not working
The dash lights in my 2001 Impala have quit working. No lights for spedometer, gas gauge, etc in the dash, also the climate control lights went out at the same time. For a short time this problem was intermittent and all lights would go in/out at once. Even when the dash lights are out, my cruise control light does come on.
I read some previous posts and a few guys suggested new headlight switch, do you think that could cause this problem? Can I test that with a test light or multi-meter before replacing the switch? Anything else to look at?
Thanks for the help guys!
Old 10-28-2009, 08:06 AM
j cAT j cAT is offline
Re: 2001 Dash lights not working
the dimmer is normally part of the headlight switch...since it was intermitent it is usually the cause ...check fuses first then confirm with a meter..if you know what your doing you could use an external resistor of the proper wattage/resistance to save a few bucks on a new switch.
Old 02-20-2010, 08:59 PM
ArthurRoberts ArthurRoberts is offline
I have the same problem, no cluster lights, But when it is daytime my radio lights work at night they don't, as with the lights to show what gear im in they work at daytime at night they don't.
Can anyone help me with this or give me some tips on what to do.
Thanks very much...
Ps. They do work at first startup and then go dim right after.
Old 02-21-2010, 08:03 AM
I apparently forgot to post back on my resoution. I did replace the headlight switch and it fixed the problem. It sounds like you may have the same problem. To double check the obvious, if you have the pull out knob for headlights, it isn't turned full one direction which turns down the dimmer is it? If not the dimmer that is build into the headlight switch coulb have gone bad, whenever your headlights come on the dimmer takes over and sets the brightness of dash and radio lights, if yours is bad that could be why everything turns off. They could be on during the day and when you first turn the car on because your auto headlights have not come on at those times. I bought a switch at a salvage yard and it worked great.
Old 02-21-2010, 08:32 AM
Thanks very much...
follow the troubleshooting instructions I gave the prior forum member then post results..
also whenever you have qestions about a vehicle it helps to know the vehicle details...
Old 02-21-2010, 08:40 AM
I have followed troubleshooting the dimmer was the problem, Thanks.
Old 02-21-2010, 08:42 AM
Thanks for the help it saved me alot of time.
Old 02-21-2010, 09:01 AM
that was pretty quick ..good luck..
Old 02-21-2010, 09:03 AM
Yah soon as i seen this i went to work on it and that was it.
Old 02-27-2010, 10:23 AM
SwitchFactory SwitchFactory is offline
Careful when buying the Headlight Switch several makes of have multiple switches.The Impala for instance using an Airtex switch has one switch without foglamps (1S1971) and another with foglamps (1S1972)..AC Delco D1599F SWITCH,HDLP & INSTRUMENT PANEL LAMP DIMR(W/HSG) W/INSTRUMENT LIGHTING SHUTOFF SWITCH(WU1) and D1598F SWITCH,HDLP & INSTRUMENT PANEL LAMP DIMR(W/HSG) W/O INSTRUMENT LIGHTING SHUTOFF SWITCH(WU1)
Old 03-06-2010, 04:19 PM
momfaith momfaith is offline
Smile Re: 2001 Dash lights not working
I have a 2001 Chev Impala with 52,000 miles .
The gearshift lights are not working. They do not lite up.
The other lights on this dashboard panel light up .
I had the battery replaced and the operating system checked .
The operating system is fine.
The new battery actually made the gear shift lights work(lite up) for
the next 7 days. After this, the gear shift lights did not work.
It was back to the way it was before I replaced the battery.
What is your opinion?
Old 10-27-2015, 10:13 PM
2ez 2ez is offline
I have 2004 Impala. Instrument lights were going too dim to see. I read over some of the previous comments. It sounded like I would be replacing the light switch. I don't like to spend money (new switch $122 locally) so thought I would try to fix the switch myself. I first removed the switch and took it apart. There are several spring loaded contacts internally. Be careful not to loose parts that will catapult themselves across the workbench. I cleaned all contacts and 'gently' stretched out the multiple spring contacts. Switch went back together with a little trial and error, getting spring contacts to stay in right position. Plugged it back into wiring harness and instrument lights are now back to normal.
Old 10-31-2015, 10:46 AM
cleaning up the contacts for some is do able, some not. many times switches can be cleaned up. I just did a brake stop switch contacts had some corrosion on them.
