Old 10-28-2009, 03:18 AM
Drift F.C's Avatar
Drift F.C Drift F.C is offline
Clear Coat
I bought a Tamiya Spray Can of Clear. Got home and sprayed it on my latest project. I let it dry and when I came back, the clear coat had made all the paint leak.
I didn't know what the problem was, can you help me???
Old 10-28-2009, 03:26 AM
gtziaf's Avatar
gtziaf gtziaf is offline
Re: Clear Coat
What basecoat paint are you use?
Any photos?
Sorry for your bad luck...
Old 10-28-2009, 03:56 AM
Khier Khier is offline
Re: Clear Coat
Sounds like you sprayed over Tamiya acrylic, right? I had a similar experience with clear paint from the hardware store. Tamiya, or perhaps all acrylics, do not stand whatever in the spray cans. Only good old hobby enamil paint (Humbrol, Revell, Testors,...) accept these paints.
Old 10-28-2009, 07:29 AM
klutz_100's Avatar
Re: Clear Coat
TS-13 strikes again?!
Either:
a) you put the clear over an incompatible base coat paint (as suggested above); or
b) you sprayed too thick a coat of this evil stuff and it burnt your base coat (which it can do even to "compatible" paints)
Old 10-29-2009, 02:43 AM
Drift F.C's Avatar
Re: Clear Coat
I managed to save the paintjob after all. I just painted the green back over the clear!!!
It still gets its shin anyway.
I used Aquieous Hobby Colour. I thought that it would work because the paint is the same as the Tamiya Acrylic. Thanks for the help, I have only been modelling for about a year full time and this is the first time I have used clear coat!!!
Thanks again, I know not to paint Clear of Acrylic again!!!
Old 10-29-2009, 02:51 AM
klutz_100's Avatar
Re: Clear Coat
Glad to hear you are happy with your save
However, bear in mind everything that was said above and here. Using clear coats successfully is not solely a simple question of paint compatibility. Specific features of individual brands of clear coats, your application styles/techniques and ambient temperatures/humidity are also huuuuuuugely important.
Do some browsing/seraching around AF and you will find a wealth of useful (and contradictory ) information.
Old 10-29-2009, 10:34 PM
Lownslow's Avatar
Lownslow Lownslow is offline
Re: Clear Coat
had that happen too
then i switched to urethanes Ts13
Old 10-30-2009, 01:30 AM
Didymus Didymus is offline
Re: Clear Coat
I'm soooo confused, but that is not unusual.
Leak? The clear coat made the paint leak? Out of what? There's something I'm not getting here.
IF you're saying that the Tamiya TS-13 made your acrylic paint bubble or ripple or something like that, then the posters are right: Tamiya TS-13 Clear Coat, aka "evil stuff," is not compatible with acrylic paint. But if that is what happened, I can't see how you could possibly get a good result by painting over the mess with a coat of acrylic paint.
So I'm still confused.
(Unlike some people, I don't have a problem with TS-13, except for its exorbitant cost. But I start with thin, dry coats, and get wetter as I go.)
Old 10-30-2009, 02:10 AM
klutz_100's Avatar
Re: Clear Coat
Originally Posted by Lownslow View Post
Ts13
Yay!!
BTW, I love that smiley! Expect to see it on here more often
Old 10-30-2009, 04:04 AM
Drift F.C's Avatar
Re: Clear Coat
Didymus Said -
I had the green acrylic running of the car on to my booth and after the clear was set, the car was nearly set hard to the box. I got my paint out and thought I could save it. I just started painting the green in a pretty thick coat over the side panels and it just looked like it would've if it didn't run. It still gets its shin!!!
Does that answer your question!!!
Old 10-30-2009, 10:37 AM
Re: Clear Coat
Kinda.
Anyhow, glad you were able to fix that leak!
Ddms
