sonoma issues
i have a 2003 gmc sonoma that has 4.3 vortec with x code i cannot get it to start it turns over batt is good im getting spark from coil fuel pump is working wit 62 psi at fuel filter and im not sure what else to check any info would be greatly apreciated
Re: sonoma issues
Is the spark getting to all spark plugs?
Dist rotor turning when cranking? Will it start with a shot of carb cleaner? If so you have a fuel delivery problem. Fuel pressure or injector pulse. Any check engine lights or codes or security lights staying on? Are the spark plugs wet or dry on the ends?
Remember proper testing gives us the answer to many problems. MT Last edited by MT-2500; 10-28-2009 at 01:11 PM. |
Re: sonoma issues
all plugs firing will not start off carb cleaner and you can smell the gas and i have 62psi when i tested the fuel system
Re: sonoma issues
What is cold cranking fuel pressure? Should be up to 64-65 lbs. Any codes or security lights on? Good Injcctor pulse? Remote starts or aftertmarket alarm systems?
Re: sonoma issues
replaced plugs distributer rotor and plu wires. now im getting a multi/random cylinder missfire reading code p0300
Re: sonoma issues
I missed on fuel pressure it is 65/62 lbs.
Put a gauge on it and drive it 30 minutes and watch feel pressure. post bback raedings. Plugs good and AC delco? Good hot blue spark to all plugs? What is the camshaft retard readings? MAF sensor good? Try cleaning it with some sensor cleaner.
Re: sonoma issues
already cleanes maf sensor pressure is 63 to 64 how do i check the cam settings
Re: sonoma issues
You need a engine capable scanner to check camshaft retard setting. It should be 0 or +1 0r -1 degrees.
