Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 10-27-2009, 07:39 PM
smokingotti smokingotti is offline
replaced alternator and battery
on 97 ford explorer battery light still comes on and battery is still discharging
Old 10-28-2009, 07:42 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: replaced alternator and battery
Do you have a question, or are you just making a statement?
Assuming you are asking why this might be happening or what to check next, I would suggest that you need to determine what is loading the system. You can do this by monitoring the current draw on the system while pulling fuses, one at a time, and seeing which one causes the drain to drop to only a few tens of milliamperes. Have you made sure the interior lights are not stuck on due to either the switch position or the door pin switch in the door latch? Have you confirmed the connections are correct at the alternator?
-Rod
