Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 10-27-2009, 05:39 PM
vinnievv vinnievv is offline
Unhappy My 1988 caprice failed emissions
Hi,
My 1988 Caprice failed emissions. Here are the readings; HC-492, CO%- 3.77
Not sure what the problem is any help will be greatly appreciated!!!
One mechanic told me i would need a catalytic converter, another one told me that is not what it failed for.
Please help!!!
Thank you,
Vinnie
Old 10-27-2009, 05:45 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Re: My 1988 caprice failed emissions
Originally Posted by vinnievv View Post
Hi,
Please help!!!
Thank you,
Vinnie
What was the NOX reading and also, what are the max limits for each in NJ?
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 10-27-2009, 05:59 PM
j cAT j cAT is offline
Hi,
Please help!!!
Thank you,
Vinnie
you have too much hc my 83 used to run at 15-20 ppm..
also the CO [carbon monoxide ] is too high ..
this is usually the EGR sticking...the valve has a spring and with time and heat this spring gets too weak..egr valves on these vehicle last about 80,ooomi.....
so when the check your vehicle the EGR is opening too much and this sends too much exhaust gas into the intake which causes these readings to be to high....not enough air...
the egr is used to prevent detonation by reducing the combustion chamber temp...this is done by reducing the oxygen level..
Old 10-28-2009, 07:59 PM
Hi,
Thanks for your replies. Could the catalytic converter cause these problems or not?
the Jersey limits are HC-220, CO%-1.20
There is no NOx reading on the faile paperwork. they did the 2500 RPM Emissions test only CO25 passed at 11.55
Thank you,
Vinnie
Old 10-29-2009, 09:07 AM
Hi,
Thank you,
Vinnie
didn't you read my reply? what did you do to check out the EGR valve..
the cat converter only works when the engine is cold and is polluting ..the cat converter cannot work continuously ..if it did it would melt...
Old 10-29-2009, 12:30 PM
j-CAT, YES i read your reply. I'm not sure how to test the EGR valve.
Thanks for your help
Old 10-29-2009, 07:07 PM
if the valve is 8yrs old or has more than 80,ooomi it is worn out..get new one..compare the spring tension to new one before installing..the new one will be stronger...spring wears out causing valve to open too much..
if you don't have the 70.oo for new get a good looking one at the scrap yard...though that part may be hard to come across...
Old 10-31-2009, 12:58 PM
j-cAT,
Thank you
Old 10-31-2009, 07:13 PM
j-cAT,
Thank you
your welcome . so you got it to pass ?
