Old 10-27-2009, 03:58 PM
cm1 cm1 is offline
95 cheokee oil filter adaptor
Hi guys, 4.0L, 170,000 mi. (upstate NY Jeep)
Heres my problem the oil filter adaptor on my son's 4.0l is leaking oil, we got a new gasket, but we could not remove the bolt holding it on, I've the right T-60 bit 1/2" DR., I evan tried a impact on it, bu it wouldn't budge eather way.
Anybody out there ever come across this prolbem, if so how did you remove it?
I do this for a living, and if push comes to shove I'll get new and then I know it'll come loose one way or the other.
Old 11-28-2009, 05:49 PM
DIVERHERB DIVERHERB is offline
Re: 95 cheokee oil filter adaptor
How did you get a impact on the retainer? Those things are so close that you can hardly get a torx bit on it. I usually work them back and forth and usually they will come loose. Sometimes tapping on the side of the adapter helps. Hope you got the complete gasket set, should be 3 orings and a gasket.
Old 12-03-2009, 08:55 AM
brainyass's Avatar
brainyass brainyass is offline
Try using a large breaker bar or slip a pipe over the end of your ratchet for more leverage. Since the clearance is so tight (unless you removed the quarter panel) I used a pipe to get mine off.
1993 Jeep Cherokee Country
4.0, 2WD, 200K+ miles
2007 Ford Expedition XLT 4X4
Old 12-03-2009, 07:47 PM
cm1 cm1 is offline
sorry I didn't get back sooner
I just wiggled the gun around and it slipped in place, just lucky I guess
I haven't had a chance to get back to it, sons been out of work, so still waiting on parts. I'll let you know how I make out.
I appreciate your responses.
