Old 10-27-2009, 03:18 PM
Justin1011 Justin1011 is offline
95 Blazer 4x4 trans problem
i have a 95 blazer 4x4 there is something wrong with the transmission, it will go into gear and move about 20 - 30 feet going forward or reverse but then it wont go any farther its like all of a sudden the tranmission isnt engaged any more. can anyone help me diagnose this?
Old 10-27-2009, 03:25 PM
laxman21's Avatar
laxman21 laxman21 is offline
Re: 95 Blazer 4x4 trans problem
Mileage?
Service history?
Trans model?
Codes?
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 10-27-2009, 03:58 PM
the mileage is around 160xxx im not sure of service history (its my buddys truck) , its a 4l60-e trans and when i scanned for codes all it pulled up was an engine knock sensor malfunctioning
Old 11-01-2009, 07:43 AM
dracer398's Avatar
dracer398 dracer398 is offline
Send a message via AIM to dracer398 Send a message via Yahoo to dracer398
I have a 95 jimmy. It has the 4L60E as well. My transmission was acting up too. A filter and fluid change with a quart of Lucas transmission lube cured mine. My problems started around 180000 miles. Converter chattering, no reverse. sluggish forward gears. I ran the Seafoam Automatic transmission additive in it first to clean the valve body then changed the filter and fluid. I have over 200K on it right now and it shifts and runs great. This might be a good fix if you don't want to do an overhaul on it. It cost less than $100.00 if you do it yourself.
