Old 10-27-2009, 09:23 AM
thewhiteshark thewhiteshark is offline
no cruise
Hi there,
93 park avenue...cruise worked intermittently for a while then nothing....I installed a new column lever ..no difference so I returned it..WHERE IS THE control MODULE? I checked the break pedal switch and it's good .I get the impression that because of the behavior before quitting that it could be a ground. Please advise.thanks
Old 10-27-2009, 09:53 AM
imidazol97 imidazol97 is offline
AF -Advisor
Re: no cruise
Originally Posted by thewhiteshark View Post
Hi there,
Are there more than one circuit through the brake switch for the cruise? Are you sure you checked the right one? It seems to me there is something that's easily overlooked there. I had a 93 leSabre where the cruise went out and the dealer replaced the unit and it worked. I assume they checked the brake switch. And then within days the new one quit working. And it turned out there was a circuit in the brake switch they didn't check.
Old 10-29-2009, 11:05 AM
Bassasasin Bassasasin is offline
Re: no cruise
I battled a "no cruise" for quite a while.
On my car it would work, indicate cruise and then wink out and quit and eventually just nothing.
The fix was a PCM module from "the yard".
Bass
00' Park Ultra
94' Park Ultra
94' LeSabre
96' LeSabre
