Old 10-26-2009, 11:42 PM
Scott2844 Scott2844 is offline
98 Grand Caravan
Wife's vehicle has been 'acting up' lately.
Have had to change passenger side turn signal light twice because it would not signal properly. Something was causing the bulb to burn out. Seems to work okay lately though. Don't know where to look for short.
Battery recently died so we purchased a new one. Van worked fine for a few days but soon starting to slowly die out. Don't rightly know if the alternator is the culprit. The lights on the dash went haywire and the van seemed to systematically shut down. Buddy of mine suggested it may be sensors, which is possible, I suppose.
When it comes to electrical components of a vehicle, I am a novice.
Any advice/suggestions would be most welcome.
Thank you.
Old 10-27-2009, 02:21 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 98 Grand Caravan
Head back to the battery shop and have them charge and load test the battery. Only way to proove the battery is good. They can probably test the alternator for you too. If it continues you may have a parasitic drain on the battery meaning something in a circuit is drawing power when it shouldn't. Here's how to troubleshoot that: http://www.ricksfreeautorepairadvice...-battery-drain
Your erratic dash lights etc are likely caused by the weak battery. These electrical systems are sensative to low voltage and voltage spikes.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
