Old 10-26-2009, 09:54 PM
Black_Blade Black_Blade is offline
How to clean engine coolant reservoir?
My engine coolant reservoir is pretty grudged up inside, making it difficult to see what the level is. Is there a solution that can be used to clean the tank up again?
Old 10-26-2009, 11:41 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
Re: How to clean engine coolant reservoir?
First of all, clean the exterior of the tank with dish soap, water and a cloth. It'll help a lot.
*If it's still dark,pump the coolant up of the tank with a fluid suction pump or a pipette.
*Disconnect the hose (it'll leak), install a draining hose instead.
*Fill the tank with dish soap and water until it cleans up.
*Rinse it with water.
*Connect the coolant hose back.
*Place the coolant back in the tank.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 10-27-2009, 06:31 AM
Thanks for the reply Serge...I thought it would take some special kind of chemical cleaner to get the staining off the inside of the plastic container. Next nice day will give your recommend a try, thank you!
Old 10-27-2009, 09:51 AM
12Ounce 12Ounce is offline
I agree with serge's posting. I would further add ...
Plan to get wet! Remove the reservoir. Plug the holes as best you can ... and half-fill with water and soap solution. Add a handful of sand. Shake energetically 'til stuff is removed from reservoir walls ... Flush reservoir thoroughly with garden hose. Reinstall.
Of course, there is no substitute for a new reservoir because the plastic reservoir material discolors overtime ... that's my personal choice once I have all the oil-to-coolant leak issues corrected.
