Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-26-2009, 07:34 PM
blazefirewolf blazefirewolf is offline
1995 Eclipse Stalls
I have a 1995 Eclipse GS and it stalls when warming up. It will start up just fine and when I put it into reverse or drive it runs fine. However from a cold start when I come to a stop the RPM falls to around 250 and the car stalls. However it only does this until it gets warmed up. Once it is up to running temp it idles about 600 rpm. What could be causing this? the injectors?
Old 11-07-2009, 12:44 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: 1995 Eclipse Stalls
Check you IAC motor, this is what adjusts and lets more air in to the motor when its cold, if its not working then the car will idle low and stall.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
