Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 10-26-2009, 08:15 PM
evildragon evildragon is offline
12v accessory power
Where on the fuse panel or where at all, can I tap for 12v accessory power?
I installed a tachometer in my car and hate having a switch to manually turn it on and off (since if it's wired to battery 12v, it'll drain it..)
http://www.youtube.com/watch?v=RmxThYoN_J4
Please help, thanx..
My one and only car!
1994 Chevy Caprice Classic LS
L99 Engine
Old 10-26-2009, 08:44 PM
j cAT j cAT is offline
Re: 12v accessory power
with a fuse installed for the tach connect to an ignition 12volt fuse,,rather than an accessory 12volt, which would be on contiuously.
use a meter to find the fuse with key on only that has power
Old 10-26-2009, 08:57 PM
I'll try probing through the fuse panel tomorrow.
If anything, I'll keep the switch for the backlight on it atleast so I can turn that on and off at will without turning the tach off.
L99 Engine
Old 10-27-2009, 04:48 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
I would ditch the switch for the light and just wire the light with the same wire used to power the tach.
You should not have to have a separate switch for the tach light. Sure the tach light will be on when ever the key is switched on but who cares.
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 10-27-2009, 04:59 PM
Originally Posted by Blt2Lst View Post
I would ditch the switch for the light . Sure the tach light will be on when ever the key is switched on but who cares.
your right ! no big deal, the tach light is on with the ignition on..
Old 10-28-2009, 04:30 AM
deesandvees's Avatar
deesandvees deesandvees is offline
Or tap into your instrument light dimmer wire.
'87 Landau
Old 10-28-2009, 05:43 AM
Well in this video you see the current situation right now at the beginning.
http://www.youtube.com/watch?v=XOXSfLE2N3I
A little switch turns the whole tach and light on at the same time.. That switch was already there, neons under the car (im no ricer, so i took them out anyway, but kept the switch just in case)..
L99 Engine
Old 10-28-2009, 08:47 AM
that I would not do...the reason is these dimmers on these vehicles can barely handle the load ,,,gets hot the dimmer resistor does..
on the older vehicles the dimmer had more load capacity..
