Old 10-25-2009, 05:52 PM
metallica21156's Avatar
metallica21156 metallica21156 is offline
90 cavalier,a/c issue
i have a 90 with the 2.2 tbi. i just replaced the a/c compressor since the old one had a leak and recharged the system. now my issue is that i can turn the a/c on and then the motor starts reving and the coolent fan starts turning on and off. i checked the a/c relay and its click on off on off like that. if i remove the relay then fan turns off and motor idles correctly. now once the a/c compressor kicks in then it idles correctly and the fan runs at full speed as it should. it did this even before the new compressor. during this i watched the pressure in the a/c system and it never drops low. what woulds cause this to happen and i've also tried replacing the relay.
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series, 2 12" audiobahns in custom box,K&N CPI intake system.
71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers.C4 tranny with shift kit, Mach 1 body lay out.
90 cav, 2.2 tbi, gas getter.
99 chevy s10 zr2, 6" lift, duel exhaust. 5 speed.
Old 10-25-2009, 09:59 PM
Re: 90 cavalier,a/c issue
also does anyone know where the diode is for the a/c compressor clutch?
