Old 10-25-2009, 03:07 PM
blsbrandy blsbrandy is offline
3.8L 95 windstar TRS Change... Any helpful hints?
We are getting ready to replace the TRS on my van. I have a couple questions...
1. My haynes manual says to mark the current position before removing old part.
What exactly am I marking?
2. The manual also says to jack up the van & put it on jack stands.
Is it really necessary to raise the van & if so will ramps work or does the weight need to be off the wheels?
3. The part comes in neutral, am I right when assume the van also needs to be in neutral?
Thanks in advance, any helpful hints are very much appreciated.
Old 10-25-2009, 06:22 PM
wiswind wiswind is offline
Re: 3.8L 95 windstar TRS Change... Any helpful hints?
You will need to have the TRS position to match up with the Gear select.....so YES the correct position would be Neutral for the Gear select.
I note that this matches up with what they say in alldata as well.
As you have the vehicle in Neutral.....put blocks in front of and in back of one of the tires....as well as setting the parking brake......to prevent vehicle movement.
I am not sure why they say to raise up the vehicle......it looks like you do the job from above.
You would remove the flex hose that goes from the throttle body to the air filter box.
Some have stated that they pretty much destroy the old TRS in removing it.......it does not just lift off.
Do NOT damage the shaft that passes into the TRS going down into the transaxle.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 10-25-2009, 10:19 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
Just mark the old TRS and the metal on the TRS. In case if you want to place back the old TRS, you know in which position it should be. So the old TRS will be in neutral.
You don't need to raise the vehicle.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
