Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 10-24-2009, 06:28 PM
sugakane24 sugakane24 is offline
i need help 89 caprice dies
i have a 89 chevy caprice wagon and it drives good for about 30 mins then dies then hard to start but when started it dies at 25 30 mph what is the deal?
Old 10-24-2009, 07:39 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: i need help 89 caprice dies
My first guess is an bad ignition coil... it's located in the distributor cap. Often, bad ones work well enough when cold, but as they warm up from running, their performance gets progressively worse.
If you change the coil, consider changing the distributor cap and rotor, spark plugs and plug wires, if you have not already done so recently.
Old 10-24-2009, 07:48 PM
maxwedge maxwedge is offline
A990 racer
Also check the inlet filter in the carb fuel line fitting.
Old 10-25-2009, 01:13 PM
anybody
Old 10-25-2009, 01:14 PM
iv done all that still the same
Old 10-25-2009, 01:42 PM
MagicRat's Avatar
Exactly what have you done?
There is no magic bullet that we can tell you about here, so please give us some more details about the work that has already been done.
Cars can fail in many different ways here, so without some more detail from you, we would end up in a lengthy, time-consuming, pointless waste of time in telling you about every possibility.
Old 10-25-2009, 02:54 PM
iv changed fuel filter, coil, plugs, wires, cont mod, clean the carb, new trane not sure what to do next the car sat for 7 years but runs great for a little and sounds great in park only dies when drive for 20 mins and then runs crappy till it sits for a hour im bought ready to sell it if i cant get it right iv had 43 cars and never ben stumped like this
Old 10-25-2009, 03:18 PM
A990 racer
I would check for proper fuel delivery at the carb, runs crappy isn't helping us from a distance, when it does this check for fuel pump volume at the carb.., There is a filter on the end of the pick up in the tank also, if the fuel delivery is weak and it has a known good fuel pump, then I would look there.
Old 10-25-2009, 04:11 PM
it has a machanical pump so there is still a fuel level sending unit in the tank then?
Old 10-25-2009, 05:32 PM
j cAT j cAT is offline
I agree with the fuel tank pick up screen for fuel supply as a very possible cause..since this vehicle sat for many years the tank may have to be droped and be cleaned out...
re-check the newly replaced fuel filter for debris/cut open the filter, debris is on the inside..
Old 10-25-2009, 07:03 PM
rhandwor rhandwor is offline
If it runs good until the engine warms up I would suspect an intake leak. Use carburetor cleaner and spray along the edge of the intake and anywhere else you could have an air leak. If the spray hits a leak the engine will smooth out immediately.
Old 10-25-2009, 07:16 PM
intake but its carb that dont make since to me
Old 10-25-2009, 08:09 PM
manicmechanix manicmechanix is offline
I totally agree on checking the fuel pressure and volume too if you can, and for any vaccuum leaks. Doesn't this have a electronic feedback Quadrajet with a mixture control soleniod, and maybe an O2 sensor? Some of them have a TPS and even a map sensor etc, not really sure if you might have a problem there but sounds like it's running bad in "closed loop".
Old 10-25-2009, 08:16 PM
These engines are very sensitive to intake leaks. As stated EGR and needing a carburetor rebuilt is very common. We were rebuilding these carburetors in the 1990's so they do need cleaned. Also spray around the base of the carburetor a very common place for air leakage. Make sure your choke is working properly.
Old 10-25-2009, 08:24 PM
Good point about the carbs needing cleaned and adjusted, and are sensitive to vaccuum leaks. Which bring up a question, does the car seem to be flooding out or more likely leaning out? And does it idle at about the right speed (idle speed, mixture and choke setting).
