Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 10-24-2009, 09:45 AM
used car guy used car guy is offline
Bose stereo problems
The stereo works all the time but the speakers shut off and on even when it is setting still! Anyone else had this problem befor?
Old 10-24-2009, 11:32 AM
j cAT j cAT is offline
Re: Bose stereo problems
if all the sound drops out this would be the connector or the amp is overheating and cutting out..check fuses for security and place a meter on the supply /ground to ensure its getting a good solid feed...
Old 10-24-2009, 11:58 AM
Thanks a bunch, will let you know if it works or if I find it.
Old 10-24-2009, 05:00 PM
I forgot to mention,,,If a speaker coil is shorted/shorting out the amp will overload and should shut off,,,protection device..
Old 10-24-2009, 05:55 PM
I did find that the driver side speaker is not working. Is this the most likely cause, you think.
Old 10-24-2009, 07:22 PM
any speaker not working correctly is suspect with your issues...
also If one speaker is bad ,,the rest are bad...
some say these speakers are great...I say cheap junk....I replaced all of my speakers,,,and come to think of it I did this shortly after buying all my vehicles new...GM uses the cheapest speakers available..when you buy a car/truck you normally don't ask what speakers are in it..
most get amps and high power speakers to overcome the GM sound issues...I found that replacing with a high quality speaker , is all that is needed. unless you what to shake the ground...
