Old 10-23-2009, 03:24 PM
Ives1 Ives1 is offline
Question Difficulty in changing belts
Hi, have a 2005 T&C Touring, 87,000 miles.
Thinking about changing belts myself.
How difficult of a job will I be under taking?
Plus anything I should watch out for in the process?
Serpitine belt & timing.
Thanks all help appreciated. Ives
Ives is online now Edit/Delete Message
Old 10-23-2009, 10:43 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Difficulty in changing belts
There is no timing belt on either engine offered on an '05 T&C.
The serp belt is easily dome with the passenger tire and splash shield removed. Use a 15mmn (I think) wrench on the tensioner to release the tension on the belt. There should be a sticker on the vehicle that shows how the belt is routed. If there isn't it won't hurt to make one yourself.
Old 10-23-2009, 11:55 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
3.3 and 3.8 ltr engines have a timing chain designed to last the life of the van. I use a shorty 15mm socket on a breaker bar with a two foot pipe on the handle for leverage to release the tensioner and remove the belt. Sears sells a purpose made extended bar with a set of shorty sockets just for the job. Edit - Not sure on 4th genearation vans (yours) but on 3rd gens I just go from up top. No need to remove anything.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 10-24-2009, 01:32 AM
Smile Re: Difficulty in changing belts
Thanks a lot for the advise. I wouldn't have known to enter through passenger tire and remove splash shield. Thanks again Ives
Old 10-24-2009, 05:39 PM
Airjer_'s Avatar
3rd generations are way easier to do through the wheel wells as well. Especially when your changing the tensioner and motor mount bracket because the belt keeps coming off! :O
