Old 10-23-2009, 01:33 PM
slantsix slantsix is offline
95 Grand Prix cooling fan problem.
1995 GP SE 3.1, fan number 2 will not activate. Checked and swapped relays, no change. Checked fuses, all ok. Checked fan motor, ok. checked with car running, AC on full, no 2nd fan. Fan number 1 works fine. Any thoughts?
Old 10-23-2009, 02:41 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: 95 Grand Prix cooling fan problem.
I think 1 fan turns on at a certain temp, and the other fan turns on when the temp is higher. I am not sure what the temps are though.
As a test you can unplug the coolant temp sensor and then start the car to see if both will run. If the PCM loses the temperature signal, it commands both fans on to keep the motor from overheating.
If only one fan runs, I would suspect maybe the fan driver circuit internal to the PCM is at fault.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 10-23-2009, 03:00 PM
Disconnected temp sensor. fired it up, both fans came on. Any other tests you can think of or should I start looking for a PCM?
Old 10-23-2009, 04:53 PM
00GTP4ME's Avatar
00GTP4ME 00GTP4ME is offline
Because both fans came on, wouldn't that lend itself more to a bad temp sensor?
2000 Pontiac Grand Prix GTP 3.8L SII V6 S/C
2000 Jeep Grand Cherokee Limited 4.7L V8
1996 Chevrolet Camaro Z28 5.7L V8
1993 Chevrolet Suburban K1500 5.7L V8
1991 Ford Probe LX 3.0 V6
1986 Ford Tempo GL 2.3L 4 cyl.
Old 10-24-2009, 12:46 AM
tblake's Avatar
In God We Trust
good call, does the temp guage work?
But I think your car might just not be getting warm enough to kick the second fan on.
Why are you worried? Did your car overheat?
Old 10-26-2009, 08:51 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I agree with Tim. The second fan will only come on if engine temp exceeds 235 degrees. It should come on when the AC is set to max and ambient outside temps are above a certain temp (sorry, I don't know what that exact temp is, but I believe it's above 80), but it won't if the AC is just on normal settings or outside temps are below the PCM programming threshold.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 11-11-2009, 02:56 PM
All is well, just didn't understand the system that well. Thanks for your help guys.
Old 11-11-2009, 05:49 PM
tblake's Avatar
In God We Trust
No problems!
Come back again with any of your questions!
